Whirlpool model lsq9549pw2. I am in the process of installing a new Short Cam Agitator Repair Kit Part Number AP3094543 and Thrust Spacer Washer Part Number 3951608. I noticed on the description -Whirlpool recommends using a small amount of grease with this kit (if no grease is present on the old thrust washer).
The grease is for the thrust washer but your kit does not come with a new thrust washer. That washer sits on top of the lower agitator and the grease goes on the top surface of it if there isn’t any there already. You can use silicone grease as a substitute.
