aGITATOR NOT SPINNING
Tub Fills With Water And Agitator Will Not Spin. How Do You Remove The Agitator To Check To See What Is Wrong?
[SIZE=3]The agitator just pulls straight up and out. Once out you should see a yellow coupling that attaches the agitator to the transmission shaft. That coupling is most likely stripped out, if you can turn it by hand you know for sure it is stripped out. Also note that his coupling is referred to as an air-bell on the parts breakdown sometimes. [/SIZE]
[SIZE=3][/SIZE]
[SIZE=3][/SIZE]
http://www.appliance-repair-it.com/clothes-washer-repair.html#GE
