Agitator re-install
I got a quick question. I saw that my softener dispenser assembly was dirty so I pulled it out. It was also very dirty on the piece that didn’t come out with the assembly. I ended up taking the whole agitator out so I could soak the dirty pieces.
My question is if I need to replace the seal on the bottom most part of the agitator when I put it back together, or it the exisiting seal will keep water out?
Thanks.
There is no seal that I am aware of on the bottom of the agitator. The seal is in the tub, so you should be able to replace the agitator with no future difficulties. Just make certain you get everything lined up appropriately.
Good luck.
