Agitator Removal Maytag Model A612S
How does one remove the this agitator. I want to clean the underside of the agitator. (We are seeing black spots on clothes after the washing cycle is complete…softener / detergent residue, perhaps?)
How would one know if it is indeed tranny oil? Is there somewhere I can look to see if that is the problem?
Thanks!
The agitator is removed by removing a 1/4" headed screw in the side of the agitator(about half way down the agitator) Its also possible that the junk your getting is soap build-up, put a cup of calgone water softener and a cup of CLEAR HOUSEHOLD AMOINA in the machine,Fill it with HOT water and put it through a FULL cycle(no cloths) REPETE 2TIMES:D OIL is YELLOW, UNDISOLVED SOAP is BLACK and GOOKIE!!!
I have removed that 1/4" screw twice thinking it would free the agitator. It doesn’t. (when pulling up on the agitator bottom it flexes from the force.) There must be something else holding it in place?
my seal around the defroster somehow got against defroster and burnt out about 4 inches of it. I replaced this and now no matter what refrigerator is set at it stays around 40* to 42* the freezer temp is fine. my question is could this be from smoke on sensor above defroster or would this be an air flow problem. I am sure That I got all parts back as should be.
