all gas stove won't ignite
All 5 stove won’t ignite, no clicking sound heard. Gas can be heard, electrical outlet is working and is plugged. Spark module replaced, still not working and instead lock/unlock switch sparked when turned. What other parts do I need to repair this stove. Thanks
ashford said:
…The lock/unlock key or sel knob, part id #40, sparked when turned.
Do you think there might be other problems?..
You will see it when you’ll take it apart. Keep us posted.
I’m not able to help you with this issue without the wiring diagram for this stove which I can not find online. If you do have one and can post it then it might help.
