The Amana freezer is sagging left to right and slightly mis-aligned causing the gaskets not to seal on the right side (worse near the top right). When I open the freezer door and measure distance, the right side opens 1/2" more than the left which is about the space between the gasket. If I lean on it, or even lift it up from the bottom it closes, but letting go, it is loose. I noticed things near that area were not frozen and there was ice build up in that region.
I saw another post with a different model # and a solution. Is this the same thing or something different?
http://www.applianceblog.com/mainforums/amana/14909-amana-bottom-freezer-sagging.html
I hope people are reading this on a Friday afternoon to save my freezerburn
Scott
