Hello!
I’m hoping someone could help me. My Amana Dryer isn’t heating up! I figured it was the heating element as this is usually the culprit from previous experiences;however, when I opened up my dryer and looked, the heating element is perfectly fine.
I took the thermostat (part #AP4045617) off the metal-carriage-thing and tested it with my digital multimeter. I’m not the most advanced multimeter user, unfortunately. I set it to ‘resistance with tone’ and I get a beep when I touch both terminals. Using the lowest ohm setting (200) I get a reading of around 00.1.
I also took off the thermal fuse assembly (part #AP4045859) and tested it with my multimeter. I don’t get a tone when testing this component - no reading on the digital multimeter (stays at 1). Does this pinpoint that the problem is with the thermal fuse assembly?
