The dryer begins to make a vibrational noise within 5 minutes of running. I cleaned the idlers and support bearings, they move smoothly, I ran the motor by itself, it seemed ok, the rest of the unit is clean inside and everything appears ok. When I put it back together without the lower cover I can see the belt vibrate as the noise begins to appear. The blower assy looks ok. I suspect the motor has an issue?? Thanks
Related topics
After 20 mins. dryer vibrates and stops | 1 | 1930 | February 28, 2012 | |
Amana Dryer stops after a few minutes | 4 | 4473 | January 7, 2013 | |
fix didn't fix | 1 | 771 | November 29, 2015 | |
Amana Electric Dryer Buzzing Sound | 3 | 8599 | May 14, 2012 | |
buzzing sound | 2 | 2257 | January 1, 2013 |
