Amana Gas Range Control Panel Display
[SIZE=2]Control Panel not working. Are there any trouble shooting steps I can follow the locate problem. [/SIZE]
— Begin quote from jose2741;466283
Jose’,
Here is a list of error codes, that pertain to your range ERC/Clock,
You didn’t mention, what exactly was wrong.
[SIZE=1][FONT=Arial][SIZE=1][LEFT]F1 [/SIZE][/SIZE][/FONT][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1]- Shorted pad button.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Arial][SIZE=1][LEFT]F2 [/SIZE][/SIZE][/FONT][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1]- Oven cavity over temperature.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Arial][SIZE=1][LEFT]F3 [/SIZE][/SIZE][/FONT][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1]- Open circuit in oven temperature
sensor circuit.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Arial][SIZE=1][LEFT]F4 [/SIZE][/SIZE][/FONT][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1]- Shorted circuit in oven
temperature circuit.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Arial][SIZE=1][LEFT]F5 [/SIZE][/SIZE][/FONT][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1]- Defective watchdog circuit in
control.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Arial][SIZE=1][LEFT]F7 [/SIZE][/SIZE][/FONT][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1]- Failure of door lock switch
sensing with door locked.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Arial][SIZE=1][LEFT]F9 [/SIZE][/SIZE][/FONT][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1]- Failure of door lock switching[/LEFT]
sensing with door unlocked.
Just so you’re aware, the majority of parts for this range, have been discontinued, and are no longer available from the manufacturer.
Good Luck,
