Amana no bake, broil, or clean
Both ignitors glow hot, but no gas flow, no bake, broil, or clean. No error codes. Burners work fine. Reading through as many posts as I can, general advice would be to replace the ignitors. Is it likely that both of them are weak? Just thought I best ask before I start part swapping. And it looks like there is only one gas valve, so that is not likely to be a problem if the burners work, yes?
Thanks.
It’s hard to believe both igniters gone bad at the same time. In order to test them you have to have a clamp-on meter to measure the current drawn by the igniter(s). You also can buy just one igniter (they are identical) first to see if it would work.
