Amana gas stove. Top burners light. Neither the boiler or oven igniter light. I did put in a new oven igniter and still nothing. Any thoughts?
I replaced the lower element and still the boiler element won’t light nor the new lower one.
Your model number is OK, but to look up your range I need a M.F.G. number something like this… MFG P1130752NE.
Do your igniters glow at all?
Do you have 120 volts AC to the igniter?
I wonder if there is a thermal fuse?
The igniters don’t glow at all. P1130755NE I did put in a new lower igniter.
The electronic control board and the gas valve are no longer available for this range.
I have no way of knowing what is wrong with your range without doing some testing with a volt/ohm meter.
If I were there I would be tracing the wiring back from the igniters to the gas valve to the EC board.
I suspect that since both igniters are out, it has to do with the electronic control board. Maybe it has a burnt wire to it or maybe a burnt trace or maybe its just quit.
I wish I had a wiring diagram. Then I could tell you if there is a thermal fuse or safety device inline with the power to the igniters.
http://www.appliancepartspros.com/whirlpool-erciii-gas-no-31944801-ap4041311.html
