the oven part will not ignite, broiler will, the igniter glows brightly but the gas does’t flow.
Replace the ignitor. It might look bright to you, but it is weak, and it does not have the strenth to open the gas valve. Just the fact that it glows, say the gas valve is good, and so is the control. Replace the ignitor. Tom http://www.applianceeducator.com/parts.htm
