Amana Range...not working
Recently I replaced the bake element in my Amana electric range. It had burst and clearly needed replacement. The range will still not heat up. I since have replaced the Oven Sensor with no luck of fixing the current problem.
My next attempt would be the oven door switch, unless there is another direction I should be looking. Help anyone?
