amana washer belt change
I noticed my belt was cracked on my washer so I ordered one and began the task but how do you take apart the pump from the motor so I can take off the belt and install new one? I see a pin in pulley but I dont want to do that if you dont have to. Many thanks
You can find the complete instructions in the Service manual (page 27).
Here are the break down diagrams for the Amana washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=704456&&model_id=17462
Thanks alot I didnt know if the pump pulls off,it must be corroded onto shaft I think it might break its so tight but oh well just have to get a pump too.What a pain in the #$* something so simple takes all day!! Thanks again
You are welcome. Try WD-40 to remove the pump.
sparks fly around turntable occasionally
Remove the turn table dish and check the paint on the bottom.
