I have a leaky tub and I bought the hub/seal replacement kit. What type of sealant can be used on the seal that attaches to the tub. This is the one above the bearing and below the hub. Thanks
This should be the stuff.
Note: This is not an easy repair and you will need detailed instructions. If you do not have them I suggest you consider very carefully if you want to do it.
If you go ahead, good luck.
