Amana Washer won't spin
I have an amana top load washer and it started to smoke. I felt it was the belt and although the belt was broken, I do not believe that was the entire problem. I replaced it and the maching will agitate, but not spin. I am guessing it wasn’t spinning before the belt broke and it only broke because it got hot. Do you know what the problem could be.
The problem could be a bad brakes or a bad transmission. You can perform the troubleshooting as described in the Service manual.
Here are the break down diagrams for the Amana washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=669061&&model_id=22193
— Begin quote from Gene;51812
The problem could be a bad brakes or a bad transmission. You can perform the troubleshooting as described in the [Model ALW480DAW](http://www.servicematters.com/maytag_library/docs/RS3100007R0.pdf"]Service manual[/URL].
Here are the break down diagrams for the Amana washer [URL="http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=669061&&model_id=22193)
Thanks for the diagrams. I also had the same problem. I am thinking that the main berring is bad. It certainly sounds like it, at least… Any input would be good :slight_smile:
