amana washer
Hi can anyone tell me how to get the back off of the washer to check hose connections inside cover . I have a water leak behind the case. Thanks
The back does not come off this model.
Take off the front by taking out the two screws at the bottom that hold it on. You can now get to screws to remove the top and this should get you to what you need.
