The Y-Tube connector that leads from the Water Valve (shown as #83 Before Filter on the Water Filter Assy drawing) to the inlet line has broken. Specifically, the little white 3-way plastic connector that merges the 2 lines to 1 broke. I ordered the new valve (AP173484) which eliminates the Y-Tube, now how do I connect this to the existing inlet line? Is there a diagram available to installing the new part [as the old part is not available any longer] :eek:Thanks for your help in ADVANCE!
Elisa:(
Hi Elisa,
This part should come with the installation instructions. If it was missing then talk to the customer service.
