The cooling fan on my Jenn-Air JGS8850 comes on when the oven temp reaches 350 or more. The fan does not turn off until I turn the oven off, nor does it go off if I reset the temperature lower (to 275 for example). I am not getting an error codes and otherwise the oven works fine (It heats up appropriately). I have read several similar posts and based on those it would appear that I either need to change the temperature sensor or the front control panel assembly. Is there a specific test that I can run to isolate which is the problem? Thanks in advance!
Related topics
Jenn-Air cooling fan | 1 | 2184 | November 11, 2011 | |
downdraft fan or cooling fan won't turn off | 1 | 3378 | October 25, 2010 | |
Repost: Jenn-Air oven fan takes hours to shut off | 3 | 3509 | November 30, 2013 | |
cooling fan limit switch | 0 | 1149 | October 26, 2011 | |
Jenn-Air SVE47600W: Oven fan won't shut off | 1 | 1589 | June 23, 2009 |
