I changed motor but need to know which wires are hooked up to the switch. If someone can look in theirs and let me know how thiers look:confused:
Do not have one but the following may help
http://www.servicematters.com/maytag_library/docs/16023083.pdf
Look behnd the control panel for the service sheet, should be there with colors of wires.
thank you found it, Do you know if the pump can be rebuilt or do you have to get new ,my pump jammed someone told me to replace it?
