ATF7000ES0 Door Won't Lock
My front load was working fine. The next load I tried to wash - all looked liked it was going well but then all the lights on the wash cycle (wash, r inse spin, etc) came on and the door lock went off. You can hear the click like it is going to work but then does this. I bought a new door lock assembly and we put that on but that did not fix the problem. What else can it be or how can I find out what it is?:confused:
Use this manual to see if you can generate an error code.
It sounds like a failure of the main control unit but see if you can get a diagnosis before spending money on that part.
http://frigidaireservicetips.com/pdfs/491_AffinityWasherManual.pdf
Note this is a big file and may take a while to download.
