baffle loose
The baffles loose on my dryer. How do I get the top to open. O don’t see any clips.
Hi KG
It is an easy process that first involves removing four screws in the door area, but what the heck, the service manual can tell you a lot better than I can, so here it is.
http://www.servicematters.com/maytag_library/docs/16023110.pdf
It should also help with your baffle problem.
Good luck, let us know if you need more help
