The elements for both bake and broil stopped working yesterday. Thought I might need to buy new elements, but then thought it odd that they would both stop at the same time. Stovetop works perfectly, no problem. I’ve been told that I need to buy a new control board / clock? Costs a bit more than I have…so just wondering if there is anything else I can do…replace wiring…something? Thanks for your help!
Pull the range out, remove the rear cover and check all wires to the heating elements. If there is nothing wrong then the control board (aka a clock) has to be replaced.
- The part number for the clock is [AP2126496](http://www.appliancepartspros.com/part_details.aspx?part_id=3586196"]AP3586196[/URL]
In case you would not be able to use the old overlay, the part number for the overlay is [URL="http://www.appliancepartspros.com/part_details.aspx?part_id=2126496).
