Bake element not working
Top oven bake element not working. Have replaced element. Have continuity on current element. Have replaced sensor. Have replaced relay board (top). Have continuity from red element wire to the following on relay board: E-2N, E-4N,OVLT, Broil, CVBAK, CVRST, COOL, and L-1. Have continuity from the element white wire to L-2 on the relay board. Where do I check next? Missus is getting so hot I probably don’tneed the oven. Any assistance appreciated.
Hi.
Does the element gets 240VAC?
Does the broil works?
f it doesn’t - check the hi-limit thermostat in L1(blk) to OR common for bake and broil.
Thank you.Post the results.
Simon.
measuring across the 2 bake element wires there is no voltage. Both wires have continuity to the relay board. New relay board from APP. Have 240V coming off of L1/L2. Also have 240V on both sides of thermostat. The broiler does work. Convection fan works. Heat sensor appears good, approx. 1100 ohms. Bake element approx. 15 ohms. Broiler element will heat oven eventually. Will bring it to temp and hold it. Bottom oven bake and broil work fine. Thanks
Hi.
Turn the power off, take one wire off the bake element and with power on check witch leg has no 120VAC (one test lid to the ground). Trace that wire to source of 120VAC.
Post the results.
Simon.
No power from L2 (e11) on the new board from APP. Yippee! Now what! Will y’all cross ship a new board?
Hi.
When you turn the oven clock to bake do you hear the relay clicking? The same with the broil?
If don’t hear the bake relay engaging then most likely it’s the clock control board [part]71001872[/part]
If both relays clicks - try another PCB [part]74006612 [/part]
Make sure there is 240VAC to the PCB.
Simon.
