bake element
i bought a new bake element for the top oven and i installed it and it dosent wrk than i installed it at the bottom and it wrks fine there, but on the top oven it dosent wrk do you u think u can help me out with that??
If neither the Bake nor the Broil are working then the problem is a bad thermal fuse (#37 on the diagram) on the back of the oven.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=112397&&model_id=264001
can someone please help me with my question???
If there is only Bake does not work then most likely the problem is a bad control board.
  • The part number for the control board is AP3767567
