Bake
Hi,
I have a baking element mystery to resolve.
When i turn the oven on, the broil element works fine, while Bake element does not heat.
Both the bake and broil element pilot lights are on.
I used a tester light and pluged it on my bake element red and black wires and the 110V light turned on.
I believe my Bake element was broken but a new one didn’t work either. I finally went to the hardware store with both elements to find out they work fine when directly plugged with a wire to a 110v electric wall outlet.
So there is electricity to the bake element and the element is fine, still, the oven do not heat the Bake element while heating the broil element.
Help sure would be appreciated.
Phil
Please check your model number and repost
Hi, my oven specs are:
Model Number: WF58TW4 Brand: White-Westinghouse
It is made in canada, I imagine between 5-10 years old, white with a mecanical timer unit.
