Balancing the tub
I purchased this machine used from a neighbor. From day one I have had problems trying to balance the tub. When looking inside it is apparent the tub is "off." It tilts to the left. Also, I just had to replace the motor coupler. My question, how do I balance it? And, if not balanced, could this be what broke the coupler to begin with?
It’s possible but not likely. Check around the outside of the tub on the bottom there should be some springs, make sure they are there and not broken or stretched out.
Nat
