I have a 12 year-old Maytag Model MDB4000AWW dishwasher which developed a leak at the pump gasket and heating element. Since these gaskets and o-rings were worn, I decided that it would be a good time to replace the other gaskets and o-rings as well. During disassembly of the motor, I did not notice where the Ball Chec was seated. It actually fell out after I removed the drain cover and drain impeller. I want to be sure I reinstall the Ball Chec correctly. Can anyone offer guidance as to its correct placement? The Ball Chec is the only part I’m not certain about. Thank you…Patrick.
Related topics
Mystery Ball Check Valve Shows Up In GE Dishwasher Pump | 7 | 3089 | September 30, 2021 | |
Help me check my check balls | 2 | 975 | July 9, 2015 | |
Check ball Placement | 1 | 2173 | July 12, 2012 | |
Maytag Dishwasher Ring Seal Placement | 1 | 1332 | December 10, 2011 | |
how to check themist | 5 | 593 | July 27, 2010 |
