The unit, during the spin cycle, will bang, clank, and walk as far as the water supply and drain hoses will let it. (If I’m not home my wife will push it back -straining her neck and back) The belt has been replaced & the floor and unit are completely level. The problem has gotten progressively worse over the past weeks/months and the contents now have to be re-adjusted 2-4x’s during spins to complete cycle. On reviewing previously posted threads it appears ‘snubber replacement’ may be in order. Please advise as to appropriateness/difficulty of this. I am competent mechanically and have a well equipped shop but do not have specialty appliance tools. Thank you for your advice and time-they are valued.
The complete instructions you can find in the service manual.
check to make sure you don’t have broken spring down below. and make sure your automatic leveler is working. if they are ok. put a couple of sand paper dicus under your front legs. stick the dicus to the floor.this should take care of the walking. even if the washer is level and if your floor is not. I found at one guys house his floor was about a inch off . with the sand paper dicus. it took care of his walking.
My machine had been getting off balance, but I thought it was how I was placing the load. Then, one night it completely fell off back to the back right hand corner. I took it apart to see if I could reseat it, and realized that the bolt on the base was bent. The counter-spring was still attached.
Tha sani-clean light on the control panel is flashing green 3 at a time…I have unplugged still nothing changes
I changed the chopper assembly, pump. and even took off the door and ometered the door latches No response on ometer with them.
. Any others suggestions that might be causing the green flashing light before my face starts to turn green:D
I was looking to other suggestions on this forum and decided to try it. I opened the door of the dishwasher after 3 seconds I hit high scrub and than energy saver and repeated the same after a few seconds all the light on the dishwasher flashed and it reset my computer and for the first time inabout a year i heard the most beatiful sound i could ever emagine water running through the dishwasher and actually working…thanks to this web site i won’t have to wash dishes:)
by hand.
What parts (name and number) are needed to convert DG110 from gas pilot ignition to electronic ignition
