beeping & flashing f2
my stove is beeping and flashes f2 please help with this problem
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=cre9400acw
I could not find any tech info on this unit.
First try shutting power off of unplugging the unit for 5 minutes or so to see if it will reset itself.
I am assuming that the unit is not heating.
Looking at general Maytag error codes F2 is often an over temperature error so I would start by checking the oven sensor and it’s wiring.
Here is a good link, take a look at 7,8, 20 and 21.
http://www.applianceaid.com/elecrange.html
