belt help
the belt snapped on our whirlpool thin twin dryer
the only #s on it are 345675-nc and (827)
anyone got any ideas how and where to order this belt???
thanks guys
If [AP2946614](http://www.appliancepartspros.com/part_details.aspx?part_id=2946614"]345675[/URL] is the part number from the old belt then the APP part number for this belt is [URL="http://www.appliancepartspros.com/part_details.aspx?part_id=2946614)
Go gettum Gene!!! Tom
The part number I posted above is the right one. Just click on the part number to order it.
Son overloaded washer now it smells like stagnant water is keeps getting worse. How can we remove the tub to clean out water?
I am just guessing, but I think the overload may have caused some to clog the drain hoses or pump and it has not completely emptied. Otherwise, hard to see how overloading it would cause stagnant smell.
is a new machine becuz mine does too after a few washings i will run a wash machine cleanser through it the product is made by tide it works wonders
— Begin quote from alaskawildflwr;140481
that you can use but if not just run it alone with some bleach
