MY QUESTION IS HOW DO YOU REMOVE DRYER LID TO CHECK OR REPLACE BELT. mY OTHER DRYER YOU USE TO PRY IN THE FRONT 2 CORNERS AND IT WOULD POP UP. iS THE SAME METHOD USED FOR MY AMANA TO REMOVE DRYER TOP
THANK YOU
THANK YOU
Here is the parts breakdown
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=NDE7800AYW
This should help
http://www.servicematters.com/maytag_library/docs/16023020.pdf
