Blower wheel replacement??
How do you get the Blower wheel off the spindle…?? It has a removal directional arrow and install… I tried to turn it and cannot seem to get it off. Is there a trick I just don’t get ??
This should help.
http://www.applianceaid.com/whirlpool-dryers.html
Check out #26.
Note: that it is left hand thread.
Also you may have to use vice grips to hold the motor shaft depending on it’s design.
It is not uncommon that the only way to get it off is to bust it.
denman said:
This should help.
Check out #26.
Denman, thanks for the advice… waiting on the other part too. Just a little surprised it’s so difficult to get off. I will
