bosch axxis dryer electric ventless
We have a Bosch Axxis ventless electric dryer (208 Volts, heat exchanger principle) for use in an apartment.
This week after 3 1/2 years of trouble-free use it began to display an F03 error and then stop running and begins beeping. We can feel that the clothes are hot so we are confident that the heater is heating. We are conscience about cleaning the lint filter and the heat exchanger.
Any ideas?
Thank you.
David
Just found my manual. Same exact issue. Check the condensation hose in the rear of the dryer to be sure it is draining into the outlet (also where the washer drains). The combo is heavy and had to take the closet door off to get to it!
Good luck
http://www.youtube.com/watch?v=KU84CrgqH_k
:slight_smile:
