The dishwasher stopped mid-cycle, no lights on at all. My wife had thought she had smelled a burning smell in previous uses, but I’m not sure. I removed the control module, all looks good, nothing smells burnt. It acts as if the control module power source is gone; the 120v input to the dishwasher is fine. I’m assuming the control module has it’s own DC power source. I reinstalled it, applied AC power, pushed the on/off switch to ON and the lights came on for a short time, then started to flicker, then went out. With the door closed, I could hear a relay on the module clicking but nothing happened. I’m guessing that the module needs replacing, but it’s quite expensive and it would be good to have a second opinion before I purchase a new one. Is there some other part in the dishwasher that could load down the module and cause the lights to go out?
Thanks for your help!
The symptoms pointed to the control module (flickering lights) but the real culprit was the connection to the power cord in the junction box behind the kick plate. One wire nut had actually melted, leaving maybe one strand of wire still connected! Not enough to support the needed current but enough to barely power the lights. Poorly done installtion 5 years ago and it just now failed. Re-connected the power cable with new wire nuts and it works fine!
