Bosch Cooktop Igniter Problem
My Bosch 5-burner cooktop has started to click nonstop on all the burners when the front center burner is not lit. When the front center burner is lit, all is well. The only way to stop it is to kill the power to the unit. I have cleaned all the exposed surfaces. I took the unit out and flipped it over, but can’t see how to access the igniter as it seem like a sealed box. Any tips?
Most likely the problem is a shorted (possible due to a spilled liquid)) ignition switch (under the knob). You have to remove all burners and the top panel in order to access the parts inside.
The model number you posted (NGT942UC) does not come up. The closest model number I found is [I]NGT932UC and I’m not sure if they used the same part numbers.
[/I]
Hi - When I start my oven, it heats to desired temp.(350) when it reaches this temp, the whole oven shuts down and panel goes bleack - then when oven is cool, the time lights up in the panel once again - About 14 months ago I had the control replaced. Do you have any Idea what the problem is. Also, the clock is set, it loses time. looking forward to your hepl. Eva
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
How do you remove top panel from Bosch 30" cooktop?
How do I remove cooktop panel from 30" Bosch gas cooktop?
I have a Bosch 30" 5 burner gas cooktop and need to remove top panel. How is that done?
