Bosch dishwasher fills but will not run
Washer fills with water but then will not run. Thought this was a motor/pump issue so I replaced the motor/pump assembly. Same symptom after replacing the motor and pump assembly. I tried to run the diag by pushing Power scrub and Rinse/hold then power button. Then push Power Scrub and Rinse/hold again. When I do that the Power scrub and Regular Wash buttons just start flashing - no test cycle ever runs. Any ideas on what this might be would be greatly appreciated. One last thing. When I use the cancel/drain buttons the unit will drain the water in the bottom just fine.
Thanks,
Bob
