We are experiencing the same problem that others report related to long cycle times and starting on 2H requiring a reset at some point and then the timer drops to 90 min or less and then the cycle finishes fine. I ran the diagnostic and the indicator reads 0 and the test runs and runs. This is described as a flow switch failure. Should I first replace the flow switch ($15) and see if that solves the problem or start with the control panel (repair/replace) which seems to be the most common solution . How hard is it to find the flow switch and where is it located?
Related topics
Flow Switch Location on Bosch Dishwasher | 1 | 1986 | May 9, 2009 | |
Bosch - who can guess the problem | 2 | 1999 | September 25, 2008 | |
Bosch Dishwasher stuck on one minute | 3 | 8497 | April 21, 2014 | |
Bosch dishwasher repair | 1 | 1381 | January 21, 2011 | |
Bosch dishwasher won't complete cycle | 5 | 22363 | June 1, 2008 |
