My bosch dishwasher soap dispenser door will not close. Any suggestions on how to correct this. I’ve removed it twice and tried to clean out the grooves it slides on and the underside of the door. Sometimes it will stay closed, but most of the time it springs back open.
Most likely the correction is to replace the dispenser assembly. If you need the correct part number, post the rest of the model number.
