Bosch DW leaking
this DW is 8-9 years old. leaking from around lower edge of front door maybe a year ago. called Bosch and someone suggested NOT covering the inlet/outlet on right side wall with any flexible cutting boards, etc. this solved the problem completely back then. Now it has started leaking from under the machine itself rather than around the door; so I assume this must be a different kind of leak. I have found the troubleshooting manual posted on this website so I will research there. Does anyone have any other advice to shorten the resolution :slight_smile:
