Bosch DW water runs even when DW is off
My Bosch SHU5316/UC12 dishwasher suddenly developed a problem with the water supply after our main water line was off for a few hours due to a water main break in the neighborhood.
The cycle was stuck on "1" for an hour or so. We opened the door we noticed that the water continued to fill the dishwasher weather the door was open or closed, power off or on. I had to turn off the water supply under the sink to prevent a flood and then drained the dw by hand.
Now when I turn it on it to a new cycle it will stay on the beginning time and continuously fill and drain, not progressing through the cycle. When doing the diagnosis procedure it shows a 4 right away.
Can anyone confirm if it is a new inlet valve that I need?
