Bosch no heat and long cycles
Ok, I’ve resoldered this thing several times to fix it over the years, but now it’s not helping so I suspect something on the board is actually damaged this time. Can someone tell me the proper control unit part number that has a design fix for this issue (burnt out relay pin)? I’d rather get one that has this problem fixed than an identical one that will just have the same issue down the road.
thanks
