Bosch On/Off Button&Switch Replacement
I need to replace the On/Off Power button & switch which is located on the top edge of the door. What is the correct method to disassemble the door to replace the button and switch? I would rather not remove the inside panel if I don’t have to. Thanks for your help. Cheers.
the inside panel does not come off easy the ouside panel comes off and should be able to access the switch from the front and also bosch like to use a lot of clips so take time and look at it good
SOLVED-
BOSCH- R/R Fascia to Access Power button ON TOP OF DOOR
Model Number: [bosch dishwasher](http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=SHY56A05UC/14"]SHY56A05UC/14[/URL] Brand: Bosch
Read Gene’s description here: [URL="http://forum.appliancepartspros.com/3586-bosch-dishwasher.html#post9200) (from page 1 of this thread). His instructions apply to this model as well and are EXCELLENT. Thank you Gene!
Note: The first six T-20 screws in his instructions are the LOWER three on each side inside the door which face the rear of the unit. The second six T-20 screws will be the six which remain on the top half of the door.
You will need to separate the plastic fascia panel from the console support structure by removing the 4 broad-head T-20 screws which are visible after you remove the console/fascia assembly from the door.
Page 26 of this by Chriscw:
http://www.cteq.ca/Doc_texte/DishwasherTraining bosch.pdf
will give pictures.
Thanks to Chriscw and Gene
— Begin quote from IslandGreco;284957
SOLVED-
will give pictures.
Island Greco - I have this exact same problem, but can’t find either the post from Gene or from Chriscw to help with my replacement of the on/off push button. Any help will be appreciated.
Scott
Scott
I believe that Gene’s post is #4 on page 1 in this thread:
http://forum.appliancepartspros.com/dishwasher-repair/3586-bosch-dishwasher.html
The link to the manual is
http://www.cteq.ca/Doc_texte/DishwasherTraining_bosch.pdf However, that link seems to be bad at this time. I’ve placed the manual here: hxxp: //www. scribd.com/doc /45470536
(remove the spaces in the link and change the xx to tt)
I hope that this helps you. Cheers
