Bosch/Siemens Model SL95A502UC/01 Issue
Hi,
I’ve read lots of similar issue but not sure how to detect what I need to fix the issue.
My DW will go through the entire cycle but not clean at all. The arms are not moving, the lower arm has water coming out of the nozzles. Check all for clogging, check the filter and all clean. I do hear a strange noise I’ve never heard before, it’s like one of those electric timer you use the turn on the X’mas tree lights.
Most post point to circulating pump, but how do I know if that is the problem? How to I check to make sure it is? Also, I see a repair kit. How do I know I need a repair kit or a new pump? The pump runs over $200. My unit is about 4 to 5 years old. Is it worth it to fix or just replace a new one? Please advise.
Frankie
