Bottom Oven Heats to 325 degrees only.
I don’t use the bottom oven that often, but attempted to use it the other day and the temperature would not get above 325 degrees. The broil element gets hot but the bottom element doesn’t. I swapped out the top oven’s bottom element and the element works fine in the top oven. So I am wondering what might be wrong? Thanks!:confused:
