Brake help.. wont spin
My Maytag wont spin. It tries to spin (However it makes a loud noise) like a teacher using fingers on a chalk board, then it comes to halt.
I change the brake rotor, thrust bearing kit, belt, stator, spring, timer, yesterday. I did notice when taking off the brake parts, it had no snubber ring, so by instruction from someone… i put back the brake like it came off, with out the snubber ring…
When I tried to put the Snubber ring on - it seem to not fit because of the off center position the washier was in i guess… so i just left it off… Can someone help me with releasing the brake it seem to be stuck.
Well I don’t think it is going to work without the snubber
Here is a link to a service manual for your model.
http://appliancedigest.com/index.php?app=core&module=search&do=search&fromMainBar=1
