Breaker trips
Dishwasher will run for about 45 seconds then it makes a loud pop noise. Then a few seconds later it will pop the house breaker. And if you reset breaker it will repeat the noise and pop the breaker. It must have something to do with the heating element when it kicks in. Any ideas?
Make that less than 3 years old.
thanks
Check the continuity between each of the heating element terminals and the ground. Replace it if there is any continuity.
I believe, due to water leak it’s better to replace the heating element in any way.
Run the same test for the hi limit thermostat.
[CENTER]The hi limit thermostat
[AP3010530](http://www.appliancepartspros.com/part_details.aspx?image=1&part_id=3010530"][/URL]
[/CENTER]
[LEFT]Check all wires.
Good luck.
Gene.[/LEFT]
In order to provide the most accurate advise I need the complete model number of the fridge.
Model #ED5GHXNLOO i Still get water at the door
Thanks,
Howie
