I just replaced the ignitor in the broiler the ignitor glows and you can hear the gas comming out but when it finally lites it blows out the flame. How do I adjust the ignitor and why is it taking so long to lite burner never use to?
Dennis,
The first thing I would do is check if the igniter is installed properly. Check the burner for a burned through holes and adjust the flame as suggested in the installation instructions (page 6).
Here are the break down diagrams for the Whirlpool range http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=57672&&model_id=250160
Your refrigerator is a side by side. The first thing I would check is the water tube in the freezer, that drops the water into the icemaker, and see if it is not frozen. If not, you have 2 water valves on that refrigerator. 1 is the before the filter water valve, and the other is after the filter water valve. If I remember right, if you take the back off the refrigerator on the bottom, if you are standing behind it, you will see the water valve, and then the second one is behind it. You need to ohm them out. If you have a meter, I can instruct you further. Tom http://www.applianceeducator.com
