Broiler - Replaced element still doesn't heat
The broiler element stopped working shortly after a cleaning cycle. I was advised to replace the element but this did not fix the problem, is there another part that should be replaced? Electricilty is flowing from the oven wiring harness to the element and the bake element has always worked fine. Thanks…
