Broken Samung Fridge Flapper
Hello,
I own a Samsung RF266AEWP/XAA with french doors. This fridge has a flapper on the left door. On the bottom of the flapper is a spring which holds the flapper against the door when the door is open. The spring is fine. BUT the plastic around the spring has busted off completely. So now I need a new flapper. I looked on the AP-Pros website and it seems like the part I need is DA97-12683C. But this is out of stock. I’ve looked on other sites and I can’t find it anywhere.
Is there a flapper that is compatible with the RF266 that I can buy instead?
Thanks for your help.
